100 amp Delco alternator on a 1655
Scott
02-26-2003 17:27:41
Has anyone tried using a large case 100 amp delco alternator on a 1655 diesel.Took a quick look at it and looks like it might fit.Just wondered if any one had done this.
IanC
02-27-2003 09:55:48
 Re: 100 amp Delco alternator on a 1655 in reply to Scott , 02-26-2003 17:27:41
You can get a replacment field (armature?) to boost the small (Delco 10SI) case to 130 amps. We did it on our 1555 to run our 5400 White air planter (the one with one motor per row). No messing around with bracket etc.
Dean Barker
02-26-2003 20:54:16
I installed a 120 amp delco on mine; I don't know if it is a large case or not. My fan has only one pulley; the new alt has two so I ran a second belt directly from the crankshaft (3 pulleys). I'll send a picture if you like. The NAPA belt numbers are 7460 and 7380; length 46 5/8 and 38 5/8. Took a couple trips to town to get the right length on the short one. Seems to work good. Did this 3 years ago.
