310 diesel
880 puller
03-26-2003 11:46:07
i would like to build a n.a. 310 diesel to put in my 880.how much power is achievable without mortaging the farm and running it at 2300rpms.any help would be greatly appreciated.
polardiesel
01-29-2004 11:19:48
 Re: 310 diesel in reply to 880 puller, 03-26-2003 11:46:07
bone stock 310's are good for 100 hp at 2400 rpm.
m kuhns
03-26-2003 13:51:09
We are running right around 140hp turning around 2,800RPM's on regular diesel and no additive of any sort. Engine is only 345 cubic inches out of a straight 310 block with only a little more stroke and stock bore. You could run more RPM's if rules allow. Price was cheap too! Patched block on left side from previously thrown rod, old pistons and liners. It has not been apart for about the last 7 years except for bearings.
880 puller
03-26-2003 14:51:11
 Re: Re: 310 diesel in reply to m kuhns, 03-26-2003 13:51:09
what size pump and injectors are running? how did you get the longer stroke. offset grind and which rods? have you done any headwork?
m kuhns
03-27-2003 15:58:37
 Re: Re: Re: 310 diesel in reply to 880 puller, 03-26-2003 14:51:11
The fuel pump has a 45 head in it. The stroke is only 1/4 inch longer than usual. I think the crank was out of another Wauheshau, maybe a 320? I can't remember. We used stock rods and have absolutely no headwork done.
880 puller
03-28-2003 11:11:59
 Re: Re: Re: Re: 310 diesel in reply to m kuhns, 03-27-2003 15:58:37
thanks for info. i will do some checking around now and see what i can come up with.
