Flushing cooling system
ATM
03-29-2003 15:47:29
What is the best way to flush the cooling system on 1655 gas?
Antifreeze mix is a little slimy would like to get it as clean as possible.
Will be adding PENCOOL 3000 cooling system treatment to prevent cavitation in all of my tractors. Thanks ATM
Ollie
03-30-2003 03:31:37
 Re: Flushing cooling system in reply to ATM, 03-29-2003 15:47:29
Coolant has a slimy feel to it. Best to check the color/smell. If it's discolored and/or has a weird smell to it, that's likely combustion gases in the coolant and that's most likely from a damaged head gasket.
If everything is OK, just open the drain at the rear of the engine (engine cold), collect all the old coolant, then stick a garden hose in the radiator and let it run 5-10 minutes. Let that drain then refill with coolant and distilled water.
