1550 Won't Idle!
Help
06-29-2003 19:26:12
I have a 1550 that runs good above 1200 rpm but will not run below that unless the choke is closed. I tried the idle mixture screw but it did nothing to help. Could the idle jet be plugged and if so is it removable to clean it?
IanC
06-30-2003 03:27:08
 Re: 1550 Won't Idle! in reply to Help, 06-29-2003 19:26:12
The idle mixture screw on a Marvel/Schebler carb work opposite of most jets. In is rich and out is lean. Also use a can of WD-40 or similar and check for a vacuum leak between the head and manifold.
