Rearend lubed
1800guy
08-19-2003 15:01:25
I drained the rearend lube from my Oliver 1800 in order to replace it. I purchased what I thought would be enough 80w90 gear lube. Turned out I drained about 7 gallons out and I only had 4 gallons to put in. I need the tractor and the local TSC is flat out of 80w90 and has been for awhile. I have plenty of 85w140 around. Any thoughts on using this instead? I don't use the tractor in the winter months... If everything is just splash bathed in the rear I can't see how using a thicker lube would hurt anything.
Ollie
08-19-2003 18:39:40
 Re: Rearend lubed in reply to 1800guy, 08-19-2003 15:01:25
No, you can't use it. NAPA carries 80W-90 in 5 gallon jugs.
CTR
08-19-2003 15:29:09
I use it all the time in an Oliver and 2 Whites.
