550 oil pressure
Aaron
04-09-1998 07:16:49
I have just finished rebuilding my 1959 550 and was wondering how much oil pressure to expect?
I didn't replace the pump just cleaned it up it looked fine. The motor spun a rear main because
of a lack of oil pressure. the oil passages were clogged badly and I want to make sure that I have right amount of pressure. All comments will be appreciated. Thanks.
mm
04-28-1998 19:55:52
 Re: 550 oil pressure in reply to Aaron, 04-09-1998 07:16:49
The standard rule of thumb on oil pressure is 10 psi. for every 1000 rpm the engine runs. I figure your 550 runs less than 2500 so 20 to 25 psi would be fine. Excessive oil pressure leads to oil consumption. The oil windmills off the rod bearings past the piston ring and finds its way to the combustion chamber. : I have just finished rebuilding my 1959 550 and was wondering how much oil pressure to expect?
: I didn't replace the pump just cleaned it up it looked fine. The motor spun a rear main because
: of a lack of oil pressure. the oil passages were clogged badly and I want to make sure that I have : right amount of pressure. All comments will be appreciated. Thanks.
