550 Knuckle Bushings removal??
550Doug
10-24-2003 11:52:57
I have a 550 Oliver with solid front axle and I need to replace the bushings (top & bottom) because of too much sloppiness. I've got the new ones ready but I can't get the old ones out. They are worn smooth on the inside so there is no lip to grab onto. Any suggestions???
Mark
10-31-2003 03:36:34
 Re: 550 Knuckle Bushings removal?? in reply to 550Doug, 10-24-2003 11:52:57
When I did mine, I cut the bushing down to the steel with a sawzall on two sides, and then use a punch. Came right out. The cut takes the pressfit out.
Brad
10-25-2003 10:34:29
They can be a challenge. usually end up using a hammer and chisel to split them and then they come out easily.
jake
10-26-2003 07:02:29
 Re: Re: 550 Knuckle Bushings removal?? in reply to Brad, 10-25-2003 10:34:29
I use a 1/2 rod and drive [from inside] the lower bushing from the top and the upper from below. There is usually enough of a lip left. What do the spindles look like?
