need help...front frame weights
770
01-19-2004 17:43:19
I bought a front frame weight for my 770. It won't bolt up. Could it be I have the front weight for a 550??? Do they look the same and accept the same stack weights??? Would anyone have the casting # for the proper weight??? Any help appreciated....John.
B A Star
01-19-2004 18:19:53
 Re: need help...front frame weights in reply to 770, 01-19-2004 17:43:19
The weights should have a number cast in them. The Row Crop tractors used a part number 101 027-A base weight, that number should be in the casting. The Super 55, 550 used 101 973-A base weight for the sheet metal grill and 156 341-A for the fiberglass grill tractors. Stack weights were part number 156 342-A for the Row Crop. This weight was also used on the fiberglass grill 550. Sheetmetal grill equipped Super 55 & 550 used 101 973-A stack weights.
770
01-20-2004 14:20:15
 Re: Re: need help...front frame weights in reply to B A Star, 01-19-2004 18:19:53
Thank you. Now I can check and see what I really have. Thanks again.....
