2250
333
01-27-2004 08:23:10
Has anyone turned up the fuel pump on one of these to get more horsepower and what can you run safely with oout replacing parts?
m kuhns
01-27-2004 09:09:27
 Re: 2250 in reply to 333, 01-27-2004 08:23:10
We have a 2255 running about 210Hp out of a 3208. We never dynoed it. We use it on our farm here in Pa. to pull our 5000 gallon tanker around weighing 80,000lbs when loaded with tractor, tanker, and manure weight combined. It is only a 2wd. Just about any hill you come to you can pull in 5th direct. We gaind a whole gear from 4th direct/under It has been that way for the past 5 years. Our 28 ft disc we can pull in 4th direct or over. Tractor has about 7,000 hrs on it. The clutch is just so it hold the Hp. If you use it in the field try to run the over/under in direct to minimize wear on it. Direct you just ruin clutch packs, direct the psrag and shaft$$$ and over the planetaries and hub even more $$$$ Good luck.
antique
01-27-2004 08:38:27
Do you have the 3150 or the 3208 Cat. Also are you talking for pulling or for farming/ Two wheel drive or four wheel drive?
333
01-27-2004 08:59:45
 Re: Re: 2250 in reply to antique, 01-27-2004 08:38:27
3208 and 4wd for farming
333
01-27-2004 08:26:14
I mean 2255 sorry
