3pth
1650 oliver
02-13-2004 05:18:31
On my 1650 when I shut off the engine the hitch does not go down, until I start it up again- is this some sort of safety switch?
Thanks
Wrenchbender
02-13-2004 05:26:48
 Re: 3pth in reply to 1650 oliver, 02-13-2004 05:18:31
Yes! The Oliver tractors have a built-in safety that requires that the tractor is running for the hyd system to work. WB.
j meyer
02-14-2004 10:13:27
 Re: Re: 3pth in reply to Wrenchbender, 02-13-2004 05:26:48
Why didnt all the manufactures make this feature on their tractors also. It just plain makes sense to me to keep the three point in place when the tractor off.
Oliver 1650
02-13-2004 09:09:23
Thanks wrenchbender, did you have any idea how that works?
Wrenchbender
02-13-2004 14:53:03
 Re: Re: Re: 3pth in reply to Oliver 1650, 02-13-2004 09:09:23
Oliver uses what they call an interlock setup. It uses hyd pressure to unseat a check valve that keeps the hyd oil from flowing. Until the valve is unseated, the trapped oil will hold the 3ph or remote cyl in place. Sometimes when the hyd oil is warm the tractor will have to be revved up a little to get the hyd to work. That is the interlock doing it's job, as soon as the hyd oil flow is increased the check valve is unseated and the hyd start to function. WB.
