weight of wide vs narrow front end
770
09-11-2004 11:55:13
My 77 is done. pressed steel all around, no hydraulics, has belt pulley and wide front. With weight brackets it weighs 4265 (13.6x38's on rear). If I change wide to narrow front end, how much weight will I lose. I would like to be 4000 lbs. Thanks for any help....
Bobby C.
09-11-2004 21:13:31
 Re: weight of wide vs narrow front end in reply to 770, 09-11-2004 11:55:13
If your replace your wide front with a 66 narrow front, you will loose over 200lbs. They are a bit lighter than the 770 narrow front.
Larry from MD
09-11-2004 15:55:56
The book says 188 pounds differance.Its allso 5.5 inches farther forward.
770
09-11-2004 17:31:56
 Re: weight of wide vs narrow front end in reply to Larry from MD, 09-11-2004 15:55:56
Thanks larry, appreciate the info.....
770
09-11-2004 17:31:55
770
09-11-2004 17:31:10
