2270
1850 guy
09-13-2004 07:07:44
Auction coming up soon in my area has a 2270 White tractor w/duals.
It looks to be similar to a 2-135 series from the photos (thumbnails). Is this a correct assumption?
B A Star
09-13-2004 07:26:53
 Re: 2270 in reply to 1850 guy, 09-13-2004 07:07:44
The model 2270 is the Canadian version of the Oliver / Minneapolis Moline G-1355, sold in Canada.
1850 guy
09-13-2004 11:20:14
 Re: 2270 in reply to B A Star, 09-13-2004 07:26:53
Are they any good? What should I be looking for if I head down to bid?
L Klingler
09-14-2004 19:17:36
 Re: 2270 in reply to 1850 guy, 09-13-2004 11:20:14
If it is the same as a G-1355 oliver or MM, then it should have the 585ci MM motor. Make sure it has an outside oil pump not an internal oil pump. MM G-1350's had an internal oil pump, the gear on the oil pump and camshaft would wear out in 1500-2000 hrs. When White got ahold of that motor they put an outside oil pump on it and made it a good motor. I think all the G-1355's have the outside oil pump, but I'm not sure. The G-1355 is a good tractor otherwise.
