just got an OC3 and have questions
ac190xt2002
09-21-2004 16:52:18
Just got an OC 3 with a loader, model is listed as OC 3 42 IND and serial number 3503061. What year is this machine? Any other info appreciated; I have shop and owners manuals ordered from this site but they have not arrived yet. From what I hear these crawlers are geared a little high for dozer work but I bought it for the loader. Thanks.
jdemaris
09-22-2004 06:40:10
 Re: just got an OC3 and have questions in reply to ac190xt2002, 09-21-2004 16:52:18
Loader or dozer, they are geared way too high. You'll be slipping the clutch and/or lugging the engine most of the time. An aux. trans. makes it a whole different machine. It was an Oliver option, or can be made. It brings the original 1st gear ground speed at high RPM from 2.01 MPH down to .64 MPH in range 1, or 1.08 MPH in range 2.
Jerry Johnson
09-22-2004 18:59:37
 Re: just got an OC3 and have questions in reply to jdemaris, 09-22-2004 06:40:10
I have a 1954 OC-3 with a Ware Loader. I use it regularly for lifting and light loading. I agree that it is too fast for heavier work. My ***** 420C with loader is much more usable primarily because of the gearing and street pads. I am interested in seeing photos of the aux transmission setup. My email is jjohnson@mpcdayton.com Thanks!
jdemaris
09-23-2004 05:49:20
 Re: just got an OC3 and have questions in reply to Jerry Johnson, 09-22-2004 18:59:37
As the other guy mentioned, go to cletrac.org My photos and data are posted there. I've put up photos and some instructions for fabrication, and also of the original factory-made setup. And yes, the Deere is geared much better. A Cletrac/Oliver HG or OC3 has ground speeds (without the aux.) as follows:
1st - 2.01 m.p.h., 2nd - 3.19 m.p.h., 3rd - 5.24 m.p.h., Rev. - 2.33 m.p.h. Compared to a John Deere 420 crawler:
1st - .875 MPH, 2nd - 2.25, 3rd - 3, 4th - 5.25 Putting the aux. into the Cletrac and using it in range one yields the following: 1st - .64 m.p.h., 2nd - 1.02 m.p.h., 3rd - 1.68 m.p.h., Rev. - .74 m.p.h. or second range as follows: 1st - 1.08 m.p.h., 2nd - 1.72 m.p.h., 3rd - 2.83 m.p.h., Rev. - 1.26 m.p.h.
RWT
09-22-2004 20:42:54
 aux transmissions in reply to Jerry Johnson, 09-22-2004 18:59:37
Take a look at cletrac.org. I saw some stuff while looking the other day and I was thinking it showed up to 3 different transmissions.
RT
Jim Brown
09-23-2004 17:38:29
 Re: aux transmissions in reply to RWT, 09-22-2004 20:42:54
I have a aux transmission for sale. It is like new comes with the bellhousing.If any one needs one give me a call Jim at 614-402-0908
Mike (WA)
09-22-2004 08:34:38
The auxilliary tranny used is a Model A Ford car transmission with a homemade "bellhousing" made from a piece of well casing. There was an article on it within the past couple of years in the HPOCA magazine.
jdemaris
09-22-2004 17:37:44
 Re: just got an OC3 and have questions in reply to Mike (WA), 09-22-2004 08:34:38
Not entirely true . . . the aux. trans. was indeed a factory made setup sold by Oliver but actually manufactured by Tractor Specialies of California. The setup you speak of was homemade and the article stunk (in my opinion). The guy had most of the work done (did not do it himself) and very little tech. info was provided. The factory setup used a modified Ford Model A (car, not truck) three speed trans. along with a custom cast-iron bell housing. I've got one in my barn and can provide photos to anyone interested. I have also made the aux. setups myself using a modified Cletrac bellhousing and an improved, removable driveshaft. The Model A transmission is well suited sinced it is very heavy duty and has full ball-bearing support on both the input and the output.
old
09-21-2004 20:06:22
Unless your loading soft stuff its still geared to high to do any real digging, or at least the one I have is but its a nice toy
J. Schwiebert
09-21-2004 19:50:48
It is a 1953 model
ac190xt2002xt
09-22-2004 09:41:09
 Re: just got an OC3 and have questions in reply to J. Schwiebert, 09-21-2004 19:50:48
Thanks for the info; will be using it mostly to load soft stuff and pick up remants of a dismantled barn. No digging or dozing, just lifting.
