Super 55 Power Steering Problems
58super55
09-25-2004 18:05:34
What is causing my power steering to lock-up? I have disassembled the the pump several times and could not find any problems. I have found that Oliver posted a recall due to the check valve was set too high. I added shims as described but this did not fix the problem. It still locks up and cause the belt to squeal. The shaft has sheard this time. The power steering is the same that Chevrolet used on their passenger cars in the 50's. The pump is mounted to the rear of the generator via an extended shaft to run the pump.
J Ulmer
09-26-2004 17:21:15
 Re: Super 55 Power Steering Problems in reply to 58super55, 09-25-2004 18:05:34
Go to www.olivertractor.com which is Larry Harsin's website. He has addressed this in his
Oliver Mechanic posts archives and runs an interactive webpage if you don't see your answer in searching his archives.
