1850 Rockshaft lift arm removal
ATM
10-13-2004 13:13:30
Need some advice on removing rockshaft lift arm to replace oil seal?
Removed snap ring but lift arm is froze on shaft any tricks on removing it.
Tried penetrating oil also a little heat wont budge.
Thanks Al
J. Schwiebert
10-13-2004 13:21:34
 Re: 1850 Rockshaft lift arm removal in reply to ATM, 10-13-2004 13:13:30
Unit on or off the tractor? If on does tractor have a cab?
ATM
10-13-2004 16:41:44
 Re: 1850 Rockshaft lift arm removal in reply to J. Schwiebert, 10-13-2004 13:21:34
On the tractor with the fender off.
I just want to pull off the one side and replace oil seal.
Al
J. Schwiebert
10-14-2004 10:55:11
 Re: 1850 Rockshaft lift arm removal in reply to ATM, 10-13-2004 16:41:44
When rusty they can be a pain. Have you tried to drive the shaft to the other side to break the rust loose?
