1850 oil leak
Aberdale Farm
10-23-2004 14:44:13
I have an Oliver 1850 with a Perkins diesel that leaks oil between the manifold and the muffler when idling for long periods of time. It makes a mess of the right side of the engine. It starts and runs fine, and only smokes a little when cold, but clears up fine when at operating temperature.
Is the oil leakage normal, or is it an indicator of something going wrong?
Dale
Kelly MT
10-24-2004 22:57:02
 Re: 1850 oil leak in reply to Aberdale Farm, 10-23-2004 14:44:13
My 1850 did the same thing when I first bought it, slobber. It was leaking by the exhaust manifold gasket. I retorqued the manifold and put it to some hard work. I also used Power Services in the fuel, helps clean the injectors. Also on that side the valve cover was leaking. I didn't find the exhaust leak until I fixed the valve cover problem. What a mess! Pk
Red Green Man
10-23-2004 15:44:38
Sounds to me like it is "slobbering". Needs to be worked hard like on a plow or disk or a good PTO load. I"ve seen several tractors that would do this.
