1755 Water pump ?
1755
10-26-2004 17:32:45
our 1755 has a waterpump that lets the fan wobel and you can feel movement I talked to the dealer he said there was a kit to rebild it if you could get someone to put it in can any one do this or do you have to have a bunch of spechel tools Thanks
Kruse
10-26-2004 20:20:33
 Re: 1755 Water pump ? in reply to 1755, 10-26-2004 17:32:45
I have never rebuilt a 1755 water pump.
With that being said, I have rebuilt dozens of
other applications in the industrial field. Usually your kit comes with (but not always)
the front and rear bearings, all needed gaskets
and may or may not have a new impeller. It should
also have the seal itself, which most of them
are now a ceramic or ceramic/teflon composition.
The best tool that you can have to replace the kit
is a press. We used an air press and have dozens
of different sized spacers and pipes to press the
seal into the pump housing.
If the 1755 takes a different type of seal and a
press is not needed, I'm sure someone here will
respond to my posting.
marc smothers
10-26-2004 17:43:28
Not hard to do at all.... Alot easier on the wallet than buying a rebuilt one... marc
edchainsaw`
10-26-2004 19:50:32
 Re: 1755 Water pump ? in reply to marc smothers, 10-26-2004 17:43:28
my dad did our 1755's water pump .. (a rebuilt one) it took a little time and wasnt a simple task but Not overly hard.
and it still wabbles a bit.. so does our 1955's.
1755
10-28-2004 14:25:44
 Re: 1755 Water pump ? in reply to edchainsaw`, 10-26-2004 19:50:32
Thanks that was what I needed to know I will try to see if I can rebild it The wabble did not bother me as much as the movement
