880 1000 rpm pto?
Adam Suess
11-24-2004 17:22:36
Any one have or seen a 880 or 770 with the dual 540/1000 pto unit on?
bastar
11-24-2004 20:59:20
 Re: 880 1000 rpm pto? in reply to Adam Suess, 11-24-2004 17:22:36
770 880 tractors were available with 540 or 1000 RPM PTO. To change speeds you have to disassemble and change the drive gears. Dual speed PTO did not appear until the 50 series. The dual speed unit was pressure lubricated by the transmission lube pump. I don't know if the bolt pattern is the same for the single speed unit used on the 770 880 as a 1650 for example. The 770 (spur gear transmission) does not have the lube pump. The 880 model with first two digits "37" in the specification number is spur gear also. 880 with first digits of 48 are helical gear & only the 880s with the field conversion Pkg have the lube pump.
