201 Continental rebuild kit
1550j
11-29-2004 17:50:45
Can you get a rebuild kit for a 201 continental engine. If so where would be a good place to get one and about how much? Thanks Brandon
Jerry B
12-06-2004 15:09:11
 Re: 201 Continental rebuild kit in reply to 1550j, 11-29-2004 17:50:45
I have a NEW 3.25 inch overhaul set I will sell for $425.
J. Schwiebert
11-29-2004 18:38:15
Is the cost an object? There are alternate methods. How good is the EXTERNAL condition of the cylinder sleeves? How well do you understand F model Continentals?
1550j
11-30-2004 03:53:25
 Re: 201 Continental rebuild kit in reply to J. Schwiebert, 11-29-2004 18:38:15
Cost is not a big deal I was just tring to get a idea. I dont know a lot about the engines. Lets say the sleeves are fine but the ring are bad can I still get them and a gasket set?I am looking to buy one and might need to rebuild the engine and have yet to find a rebuild kit for it.
george md
11-30-2004 20:24:41
 Re: 201 Continental rebuild kit in reply to 1550j, 11-30-2004 03:53:25
Brandon, My guess as to why J S asked you about the condition of the outside of the sleeves is that they can be bored and dry liner installed to get it back to standard . If the piston is not cracked or broken , reuse it . If the ring lands are worn repair with groove inserts . I just recently bore and sleeved a sleeve for an ED 208 cont'l. I made a fixture to hold the sleeve and bore with cylinder boring bar .
george
J. Schwiebert
12-01-2004 07:45:11
 Re: 201 Continental rebuild kit in reply to george md, 11-30-2004 20:24:41
More or less that is what I had in mind. The sleeves were 3.125 although 3.250 aftermarket sleeves were available. You can bore them to take an oversize aluminum piston and you have a new straight and round cylinder bore, new pistons,etc. It is less money than a rebuild kit and does the exact same thing. A lot of F model Continental parts wil fit or can be adapted to the DS201 engine. George is a good shop man.
