550 upgrade
550Doug
12-17-2004 18:18:14
I have recently purchased a new cluster gauge from Korves Oliver for the 550 and discovered that it needs a Neg ground system to operate properly. I took the opportunity to rewire the voltage regulator and generator with new wires, and I polarized the regulator. So far so good! Everything works hunkydory (amp idiotlight, oil idiotlight, fuel gauge and water temp). However, I now notice that whenever I turn on my headlight switch, both idiot lights (amp & Oil)light up and won"t go off until I switch off the headlights. I had the generator tested for output and it is producing 50+ Amps, so I don"t think I"m short of power to run 4 headlights. Any ideas to why these idiot lights are wacky??
Thanks
86turbodsl
12-31-2004 15:46:27
 Re: 550 upgrade in reply to 550Doug, 12-17-2004 18:18:14
Unless I was trying to keep the tractor original, I would not spend two seconds on the generator, and would swap to a delco 12V alternator quicker than you can spit.
J. Schwiebert
12-17-2004 18:31:15
Boy if I remember the gauges sense VOLTAGE, When you speeded the engine up voltage also increased and made the idiot lights go out. I am surprised you can get 50 amps out of that generator! Have you had a voltmeter on the system.
550Doug
12-17-2004 18:39:12
 Re: 550 upgrade in reply to J. Schwiebert, 12-17-2004 18:31:15
Yes you are correct, idling at 500 rpm the idiot lights are on, but upon reving up to 1000+ rpm they go out. The generator output was measured on a bench at the shop where it was rebuilt.
J. Schwiebert
12-18-2004 04:24:26
 Re: 550 upgrade in reply to 550Doug, 12-17-2004 18:39:12
Now you have me interested, I still would like to know where the 50 amps came from when Delco rated them at 20. Have you put a voltmeter on the system? On which terminal or how do you have the lights hooked in the system?
550Doug
12-18-2004 07:53:43
 Re: 550 upgrade in reply to J. Schwiebert, 12-18-2004 04:24:26
The lights are wired to the "L" terminal of the regulator
J.Schwiebert
12-18-2004 08:43:33
 Re: 550 upgrade in reply to 550Doug, 12-18-2004 07:53:43
Answer me this: Have you had a voltmeter on the charging circuit and or do you have say 14.2 volts when your idiot lights are on?
550Doug
12-18-2004 13:11:23
 Re: 550 upgrade in reply to J.Schwiebert, 12-18-2004 08:43:33
I have 14.7 volts with no lights on and 14.5 volts when the light switch is on (with idiot lights). I took this measurement at the "L" terminal of the regulator.
J. Schwiebert
12-19-2004 08:17:25
 Re: 550 upgrade in reply to 550Doug, 12-18-2004 13:11:23
Somehow I need to talk to you I have questions. Either find me on the HPOCA site and send me a PM or find me on the Oliver Gang site.
J. Schwiebert
12-18-2004 15:10:59
Let me sleep on that untill Monday. Too many holiday things to even give it some though this weekend. See if you can send me a personal message on the HPOCA site.
jlove
12-20-2004 08:02:59
 Re: 550 upgrade in reply to J. Schwiebert, 12-18-2004 15:10:59
Anyone replaced the steering collum links(looking at power steering)
add on for 550 linkage) Just the question ?
undecided about need to.
J. Schwiebert
12-20-2004 17:00:38
 Re: 550 upgrade in reply to jlove , 12-20-2004 08:02:59
To be honest about it. I do not fully understand your question.
