1600 drive shaft parts
560man
12-29-2004 16:26:19
i need all the parts to take the two speed out of my 1600 and install a strait drive shaft if you have these please let me know email or call 804 556 4750 thanks
Max Edlin
01-29-2005 11:58:28
 Re: 1600 drive shaft parts in reply to 560man, 12-29-2004 16:26:19
If your hydra-power is in good shape I would consider trading my shaft etc. for it. Only if the hydra power does not need rebuilding.
Don WI
12-29-2004 17:58:44
What's wrong with the hydra power that you're taking it out? Might be just the same price to fix it and keep it instead of losing 1/2 of your speeds. Donovan from Wisconsin
cobroller
12-31-2004 18:22:35
 Re: 1600 drive shaft parts in reply to Don WI, 12-29-2004 17:58:44
The shaft, couplers, and coupler chain cost about $840 new from Agco. A&I has after market parts which should be less. You either have to find the clutch housing with the release bearing tube or bolt the front cover of the hydra power to the clutch housing you have. Like the other post says-not cheap and you lose half your speeds. Advantage is you can replace the clutch without pulling the engine.
