1365 Start-up low oil pressure
Dwight Cole
07-31-1999 09:21:23
When I first start up my 1365 Oliver it doesn't have any oil pressure for about 10 seconds. I was wondering if there is a check valve any place in the oil system. The oil filter sets upside down and when I remove it there isn't any oil in it. I installed an oil filter thats suppose to retain oil but it still doesn't have oil in it when I remove it.10 seconds after start up the engine has 60 pounds of oil pressure. Any help would be very much appreciated.
Chuck
03-13-2002 10:02:15
 Re: 1365 Start-up low oil pressure in reply to Dwight Cole, 07-31-1999 09:21:23
My 1655 and 1855 are both the same way. Both the service manual and operators manual for each says that after the tractor starts, you should allow it to idle at the lowest setting until you build pressure. Since mine are both like that, I would try to find a manual to see if yours make similar mention.
