12 VOLT SYSTEM FOR A SUPER 55 OLIVER
JOHN YORK
08-04-1999 19:31:46
WOULD LIKE ANY INFORMATION ABOUT CONVERTING A SUPER 55 FROM 6 VOLT TO A 12 VOLT SYSTEM. IT DOES NOT HAVE TO BE ORIGNAL. LOOKING FOR THE CHEAPEST AND BEST WAY TO CONVERT IT.
THANX FOR ANY HELP WITH THIS LITTLE TASK
Dennis H.
08-04-1999 20:24:28
 Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to JOHN YORK, 08-04-1999 19:31:46
1) a single wire self excited 12v alt
2) a 12v coil
3) a 12v battery
Change the polarity on the battery to neg ground, remove all the wiring from the gen and the volt reg to the amp meter and replace with a single wire. If you want to keep the same 6v bulbs in the lights, you can use a voltage reducer between the ignition switch and the aux wiring.
I have a remanufactured parts factory locally and got the single wire alt for $45, a new 12v coil $15, a new blem 12v battery $25. The wire I had on hand and I also changed out the bulbs. Good luck to you.
Paul Stanley
08-04-1999 23:25:18
 Re: Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to Dennis H., 08-04-1999 20:24:28
I didn't know there were 6 volt Super 55s ..... ..... .....
John
08-05-1999 04:55:55
 Re: Re: Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to Paul Stanley, 08-04-1999 23:25:18
I think all "supers" were 6 volt until 1958.
Bob Skurka
08-05-1999 14:36:56
 Re: Re: Re: Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to John, 08-05-1999 04:55:55
I believe all Super 55s were originally outfitted with 2 6-volt batteries in a 6-volt configuration.
I just can't understand why someone would want to change over to a less complicated more reliable and cheaper to maintain electrical system!?!
Pete
08-05-1999 18:52:47
 Re: Re: Re: Re: Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to Bob Skurka, 08-05-1999 14:36:56
Guys - All diesels were 12 volt systems - but the early HC engines were all 6 volt systems - don't know what year they went to 12 volt on the HC engines but started with sn 46 001
Pete
Chris Losey
08-05-1999 21:17:42
 Re: Re: Re: Re: Re: Re: 12 VOLT SYSTEM FOR A SUPER 55 OLIVER in reply to Pete, 08-05-1999 18:52:47
All Oliver tractors came with 12 volt systems starting in 1957. Before that it was just the diesels.
