adjustable wide front won't adjust.......
770
01-23-2005 15:51:16
Trying to adjust my neighbors 77 wfe. This thing won't budge....No cracks or welds in it so I want to be careful.....Any "trade secrets" that would help??? Just rusted solid I guess. Thanks for any ideas....
Chad (IA)
01-23-2005 17:59:30
 Re: adjustable wide front won't adjust....... in reply to 770, 01-23-2005 15:51:16
This is not uncommon. With mine it took 2 guys heating it until it was red hot and beating on it a day and a half. Good Luck.
Steven
01-23-2005 16:47:54
I had the same trouble on an 1850 once. On the 1850 I took the "U" clamp off and removed the horizontal pin that goes through the axle tube. Replace that pin with a long 3/8" or 1/2" bolt (for safety). Leave this bolt loose so you can check to see if you have any progress. Spray lots of WD around and between the 2 tubes. I drove mine up to a cement grain bin foundation, putting the tire against the foundation and letting the clutch out slowly. After several tries at this, mine moved slightly. Spray WD again. I hooked a heavy come-a-long and chains between another tractor and the wheel hub and pulled it as far as it would go that way (with the bolt still in). I jacked up that side of the front axle, took the tire/wheel off and then hooked the come-a-long to the back axle, took the bolt out of the tube and would pull it back and forth many times changing it from the other tractor to the rear axle until it would move enough to pull it out of the axle tube. I was lucky and didn't damage anything on the axle or steering.
On another tractor I had to heat the outer tube with a torch to get it to move. Good luck.
edchainsaw
01-25-2005 19:31:38
 Re: adjustable wide front won't adjust....... in reply to Steven, 01-23-2005 16:47:54
Steven we did something very similar on a 1755-- chained the axle (totally unpinned) to one tractor-- pulled backwards w/1755 till it moved.
Soaking of course
then drove back forward to take out slack and pulled back with come-a-long
repeated 5 or 6 times till lose then come-a-longed sideways to pull it out..
