1550 brakes
kevin
08-13-1999 02:14:11
my 1550 brakes need replaced. how hard of a job as it? also, where can i order parts on the web? thanks kevin
Dick L in NW Ohio
08-13-1999 06:28:13
 Re: 1550 brakes in reply to kevin, 08-13-1999 02:14:11
Easy! Remove the three bolts that hold on the cover. Watch out it's a little heavy. remove out side brake disk, remove ajusting nuts, pull out the brake actuator, remove inside disk, take the springs off actuator check ball bearings and clean, add small amount of grease put springs on and assemble. I don't know about parts on the web but any White dealer or order from CT Farm store ect. If I missed any thing some one will post it for you.
Paul Stanley
08-15-1999 10:47:57
 Re: Re: 1550 brakes in reply to Dick L in NW Ohio, 08-13-1999 06:28:13
Is that actuator like the Super 55, two metal discs with three ball bearings inbetween, with two springs holding the whole thing together? If so, my dealer told me NOT to put the grease on the ball bearings, as it dries in the sockets and the bearings grab..... ..
