OC 46
ac190xt2002
03-04-2005 16:35:11
Anyone know the specs for an OC 46 crawler/loader such as # of gears, HP, ground speeds, etc.
wilson
03-07-2005 13:49:13
 Re: OC 46 in reply to ac190xt2002, 03-04-2005 16:35:11
I have some steering clutch plates ad parts I dont need if someone is interested
770jdman
03-04-2005 19:59:41
An oc-46 is 4 speed 1.5, 2.4, 3.4, 5.2 mph . Weight is 8100 lbs. could give you a complete spec. list even with ground pressureif you'ld like
J. Schwiebert
03-04-2005 19:30:12
OC-46 should have a 4 forward speed transmission. Now there are 2-1/2 versions of the basic OC-4 tractors. The first ones have a 4 cylinder L-head IXB Hercules gas engine. Later ones have a 3 cylinder overhead valve Hercules engine. It can be gas or diesel. When production was moved to Charles City from the old Cleveland plant they were known as the OC-4 (OC-46 in your case) series B tractors. OC-4 is the base tractor OC-46 means it is the loader version. Now those things will afect weight etc. Questions?
oliver-newbie
03-04-2005 19:20:30
Mine has 3 forward 1 reverse and a travel reverser
When it was new the gas engine was 30HP. Probably a bit less these days :-)
1st gear 1.5mph
2nd gear 2.4 mph
3rd 3.4 mph
rev 1.6 mph
Some had an optional slow-low which reduced 1st gear to .8 mph
Anything else I can tell you?
