WFE
03-11-2005 21:06:28
Re: Oliver Green, which is correct? in reply to j meyer, 03-11-2005 20:02:01
Right you are, Justin. Too many of these 50 and 55 series Ollies get a coat of green that is far too dark. The clover white is equally hard to match to original Oliver. None that I have found are 'dead-on' and need to be adjusted by custom-mixing. Adam, what I would do is take your time and if you can put off the painting for a few days beyond Monday, and there is some original paint somewhere on the tractor, get it computer-matched to that protected paint. The best areas to look will probably be in/around the rear end housing, especially if those areas have been covered with grease and protected from sun-fade. The underside of fenders or side panels are also often good for paint matching. When I have tried to use AGCO meadow green to paint areas of one of these Olivers, it comes very, very close to matching the original paint, but is still a bit too dark, unless there is inconsistency in the AGCO meadow green. I have used the Martin-Senour Oliver green recommended by Lyle Dumont, and like it very well. It costs about twice as much, but the color and quality of shine once cured is like an automotive finish, well worth the extra. You might try adding some hardener in whatever you choose to work with for that extra luster. Take pictures, or better yet, Justin and I will come over to see it once it's done, and drool!!
