60w/oOILpsi
3rdgenfan
03-12-2005 11:53:24
I have a 60 i went through and overhauled. now it dosent have any oil psi. what did I do wrong?
J. Schwiebert
03-12-2005 12:43:22
 Re: 60w/oOILpsi in reply to 3rdgenfan, 03-12-2005 11:53:24
Well you leave the door open for many suggestions, but did you have stem out of the oil filter and loose the little restrictor disk behins it?
3rdgenfan
03-12-2005 13:07:34
 Re: 60w/oOILpsi in reply to J. Schwiebert, 03-12-2005 12:43:22
I didnt take that apart. I pulled a plug out of the block and didnt get oil so i pulled the pan dropped the pump and ran it with a drill and it seem to have great flow
J. Schwiebert
03-12-2005 18:16:40
 Re: 60w/oOILpsi in reply to 3rdgenfan, 03-12-2005 13:07:34
Alrigh especially if you still have the pan off. Do you know what a bearing leak detector is?
3rdgenfan
03-13-2005 05:53:02
 Re: 60w/oOILpsi in reply to J. Schwiebert, 03-12-2005 18:16:40
not a clue.
J. Schwiebert
03-13-2005 08:45:56
 Re: 60w/oOILpsi in reply to 3rdgenfan, 03-13-2005 05:53:02
I thought maybe air pressure might work to. Do you have the pan off. First of all was the block 100% disassembled and hot tanked or oven cleaned. I gues I would suspect there is a pipe plus missing at either the front or the back.
3rdgenfan
03-13-2005 19:10:43
 Re: 60w/oOILpsi in reply to J. Schwiebert, 03-13-2005 08:45:56
the block was tanked I will check for a missing plug. Thanks a bunch!!
tractorptsguy
03-13-2005 19:18:28
 Re: 60w/oOILpsi in reply to 3rdgenfan, 03-13-2005 19:10:43
There is a slim chance that the pressure relief valve is stuck. I'm uncertain where it's located on the 60. On the fleetline tractors it's in the oil gallery on the outside of the block, toward the front as I recall.
