Oliver 60 RC Serial #
5th Wheel
03-15-2005 09:08:56
I have a 60 RC and was wandering where that the serial # is located on this tractor???
Thanks
chparks
03-15-2005 14:28:55
 Re: Oliver 60 RC Serial # in reply to 5th Wheel, 03-15-2005 09:08:56
The brass tag if it is there is on the left side
of the engine standing behind the tractor.
J. Schwiebert
03-15-2005 12:29:43
There should be a brass tag on the engine block that has the serial number.
5th Wheel
03-15-2005 12:41:06
 Re: Oliver 60 RC Serial # in reply to J. Schwiebert, 03-15-2005 12:29:43
If that tag is not there, is the s/n stamped anywhere on the tractor??
J.Schwiebert.
03-16-2005 16:29:15
 Re: Oliver 60 RC Serial # in reply to 5th Wheel, 03-15-2005 12:41:06
Do you have a 4 speed or a 5 speed (bent or straight gearshift hnadle) Also what is the engine number of your tractor? It is stamped in the block on the carburetor side toward the top front of the block
