Need more power from a 66
66 power
03-23-2005 04:33:35
Can anyone tell me some thing to do to the motor of a 66 to get more power. Any parts that I can interchange, carb, head, manifold. Looking to build a pulling tractor out of this one and not real familiar with the Oliver line.
Thanks
C.Shaffer
03-25-2005 07:19:31
 Re: Need more power from a 66 in reply to 66 power, 03-23-2005 04:33:35
I have a 207 cube motor for sale. Brand new, no hooks. Started for another person but he never sent a deposit or returned calls. Will give you around 65 hp. Call or email, 1-585-335-9274 before 6pm EST
deeane
03-23-2005 18:33:59
head and intake ..carb and cam from a 550 or 660 will liven it up quite a bit for stock farm pulling..bigger pistons and sleeves are also available...mill head some..all depends on how much you want to spend and what class you want to pull..can also get a 550 crank and offset grind it 1/4 in for more stroke but then have to get custom pistons or rods...there is a guy around here running oldsmobile small block pistons in his but he did a lot of work on the block and had darton make sleeves to fit...hope this helps some
