55 Seris Trans presher gauge
1755
03-24-2005 15:03:33
I was at the salvage yard and they had a old Case like a 1370 or sometheng like that it did not say but other than some other peases off it looked to good to be in a salvage yard but I craled in and satin the seat and looked at the gauges and it had a trans presher and temp gauge I was wandering if I could put a trans presher gauge on our 1755 The over/under I would think would slip if presher was low but the trans/Rearend I dont know if you would know about low presher untel it is to late I dont have my books hear they are out at the farm I was wandering if anyone has experiance with this Thanks Thomas
Lyle Noland
03-31-2005 17:00:36
 Re: 55 Seris Trans presher gauge in reply to 1755, 03-24-2005 15:03:33
I have a 1755 oil line came off inside the trans and took mainshaft out so we put pressure gauge in off of the line at bottom shaft on front of trans used fuel pressure gage low press 2psi
1755
04-01-2005 18:32:57
 Re: 55 Seris Trans presher gauge in reply to Lyle Noland, 03-31-2005 17:00:36
I thought there would be a way I thought there would be more presser than 2psi Thanks Thomas
