Super 55 brake cross shaft seal
86turbodsl
04-06-2005 05:41:50
Does anyone have a good way to replace the brake cross shaft seals? The book says to remove the wheels and brake levers, shaft, etc. My tires are loaded and that would be a lot of work.
Any ideas?
JD in da UP
04-08-2005 04:32:33
 Re: Super 55 brake cross shaft seal in reply to 86turbodsl, 04-06-2005 05:41:50
I pulled the brake pedals and keys, then pushed the shaft one way til I could pull the seal, then shoved the shaft the other way and pulled the seal on the other side. It still leaks, because the shaft and bushings must be worn a little. You can change just the seal this way but it would be better to just do it all right.
Super 55
04-06-2005 06:40:51
My wheels were already off when I took mine out, but I don't see a way around that. But you could just take one wheel off. They shouldn't be so heavy that you can't just block up the rear end, remove the wheel, and roll it back and lean it against something. Just be sure to secure it well, it may be just a bit hard to pick it back up.
86turbodsl
04-06-2005 18:21:35
 Re: Super 55 brake cross shaft seal in reply to Super 55, 04-06-2005 06:40:51
That's what I was afraid of. Thanks for the info. I'll have to gather everything before I start.
