IXB3 HERCULES
ALLEN N
04-13-2005 04:53:49
NEED HELP, HOW DO YOU TIME GOVERNOR GEAR TO CAMSHAFT? ALSO CAN FLYWHEEL GO ON 180 DEGREES OUT. ENGINE IS IN CLETRAC
Larry from MD
04-13-2005 16:18:44
 Re: IXB3 HERCULES in reply to ALLEN N, 04-13-2005 04:53:49
The one i have it does not matter as the mag drives form the other side.Here goes how i think it should be.The lugs for the mag are the important thing.So to time the mag turn it backwards untill it comes up against the impluse.You are supposed to be able to install the mag in this position,so the lugs on the govneer have to be set so the mag WILL GO IN like this.
allen n
04-14-2005 05:54:54
 Re: IXB3 HERCULES in reply to Larry from MD, 04-13-2005 16:18:44
thanks larry and old for the help
old
04-13-2005 08:36:03
I can't tell you how but I bet Zimmerman could, and he also has the books on them
