1800c transmission fill
1800c Tom
05-30-2005 15:37:00
I have purchased a 1800c tractor. Bought the owners manual. It is unclear where to fill the trans. Is the fill plug at the top of the pto housing for both the transmission and the final drive? Thanks
w.burrow
06-01-2005 10:57:35
 Re: 1800c transmission fill in reply to 1800c Tom, 05-30-2005 15:37:00
i have an 1800 a series and it has the plug in the pto housing but it also has 2 1" plugs in the side of the transmission on the left sid under and slightly back of the clutch pedal. are these check plugs or fill plugs or both.
J. Schwiebert
06-01-2005 15:31:21
 Re: 1800c transmission fill in reply to w.burrow, 06-01-2005 10:57:35
It is good that you asked. This forum is to help people keep their equipment in good operating condition. They are both fill and check plugs. Those transmissions have a solid wall beteeen the transmission and the final drive. That is why there are two check plugs. Also keep an eye on the oil levels. Some would transfer oil from the front compartment to the rear compartment and some just the opposite and some behaved the way they were designed. Also for any A or B Series 18 or 1900 without an add on transmission oil pump put the gear shift in the low speed neutal if you need to run the tractor for any PTO work or just to let it run for maore than several minutes. Questions?
J. Schwiebert
05-30-2005 18:22:21
On a series C it is one compartment. The oil will run in the transmission from the fill hole.
