1250 Oliver 3 pt
hopeless
09-10-1999 19:07:58
i have a 1250 and its always one thing or the other i like the tractor but when i cant fix it i dont got the engine going now cant get the 3 pt to work. Worked fine the other day took off mower and and tried to put it back on and i have no lift when lever is in the up position nothing happens and then put it halfway down the arms come part way up and lose it again when lever is put up can hold arms up and some presure comes against it but falls slowly back down anybody have any ideas if so thanks. Todd
Rhonda
07-03-2000 06:32:07
 Re: 1250 Oliver 3 pt in reply to hopeless, 09-10-1999 19:07:58
Hi:
We have an Oliver 1250 and recently had the same problem. There is a cam on the control lever that gets stuck from dirt and rust. I loosened ours up with WD40 and kept working it back and forth. It works fine now. Hope this helps.
