1855 PTO won't turn off
1st Oliver
07-07-2005 09:52:55
I just purchased a 1855 Diesel with over/under trans. The PTO runs continuously and will not shut off. What is wrong? Bad clutch? Any information would be appreciated.
J. Schwiebert
07-07-2005 14:45:29
 Re: 1855 PTO won't turn off in reply to 1st Oliver, 07-07-2005 09:52:55
The PTO on an 1855 is activated with hydraulic pressure. The control valve also has a brake position. Now I am trying to remember a couple other things to go along with that,( I will probably think of them later) but if you have a manual you might want to check your adjustment which is a detented position. Questions?
1st Oliver
07-12-2005 18:28:18
 Re: 1855 PTO won't turn off in reply to J. Schwiebert, 07-07-2005 14:45:29
M. Schwiebert thanx for the information and assistance. I need to replace the grease in the back valve as you mentioned. Do I clean out the old grease and repack the housing. How much is enough grease? I am enjoying my Oliver, but the systems are new to me.
bradk
07-07-2005 16:54:23
J Schwiebert is right it's hydraulically operated. I just recently bought a 1755 gas which had same problem. The linkage was hard to move due to rust.Once loosened up w/ PB blaster it would go to the stop position & engage PTO brake & make sure lever isn't bent.Let us know how it turns out.~brad
1st Oliver
07-12-2005 18:24:32
 Re: 1855 PTO won't turn off in reply to bradk, 07-07-2005 16:54:23
The PB Blaster did the trick! Thanx for the info and assistance.
J. Schwiebert
07-07-2005 20:07:34
That is part of one of the things I was trying to remember, the other part is if you pop the top off that valve there should be grease inside there too. Got to think a little more. Thanks for reminding me.
