What kind of 88dsl motor do I have
AC
07-19-2005 20:14:51
I need to order a gasket kit for my 88dsl, SN 142XXX. Do I have a dlb or a dsb engine? also where is the SN on the block? the block says 8-1952 on the back...
J,Schwiebert
07-20-2005 15:45:06
 Re: What kind of 88dsl motor do I have in reply to AC, 07-19-2005 20:14:51
First of all the key trick is what is thebore of your engine. If the 3.750 bore sleeves and pistons have been installed you need to have a Super 88 head gasket. It is still 3.500 bore which I really doubt in this day and age you will need a different gasket. It is has 3.875 M & W sleeves and pistons you will need a different gasket than either of the other two. Questions.
AC
07-21-2005 04:35:15
 Re: What kind of 88dsl motor do I have in reply to J,Schwiebert, 07-20-2005 15:45:06
It's 3.75, but my felpro book asked for a s/n because it said there are two different variations. A DSB and a DLB. I need to have this motor back together and running by Wednesday. If the Rear mains seals are the same, that's about the only difference I can think of...
J,Schwiebert
07-22-2005 08:39:22
 Re: What kind of 88dsl motor do I have in reply to AC, 07-21-2005 04:35:15
If you put the incorrect gasket on it will either hang in the bore or going the other way I have seen where the sleeves will crack. If the rear seal is the original type they are the same. There was a kit to put a lip seal in. The original equipment is a Victor head gasket. The rod bearings are not the same either. I would have it apart and measure things up first.
AC
07-22-2005 21:24:51
 Re: What kind of 88dsl motor do I have in reply to J,Schwiebert, 07-22-2005 08:39:22
OK thanks
