1855 gas to diesel
1950MFD
08-10-2005 10:46:39
can anyone tell me if a perkins diesel motor out of a white combine will bolt into a 1855 gas without to much modification?
Shep Va
08-10-2005 12:41:32
 Re: 1855 gas to diesel in reply to 1950MFD, 08-10-2005 10:46:39
Only if you have the tractor accessories for the engine and you have an 1850 diesel frame for the tractor.
In short the answer is yes, a perkins combine engine will fit into an 1855 if it is the correct Perkins engine, but not easily. You will need a different bellhousing, flywheel, pto hub, exhaust manifold, oil pan, and you will need the 1850 tub frame to replace you gas frame. Plus some things I have probably forgotten.
You really need to find a blown up tractor engine to steal all the parts off of to do this conversion cheaply.
Good luck
1950MFD
08-11-2005 10:27:46
 Re: 1855 gas to diesel in reply to Shep Va, 08-10-2005 12:41:32
thank you for the info. I was just tossing around some different ideas and wanted to save some money. I may just fix the gas motor if there is not to much wrong with it when I get it apart.
