Front mount hyd pump failure??
550Doug
09-07-2005 16:53:56
I'm not getting any hyd oil from my front mounted pump on my White 2-44LL (Oliver 550 Industrial). I've checked the filter screen at the hyd tank and it was clean but collapsed. I've fixed that but still no fluid from the pump. Can these pumps be rebuilt by a novice like me or is a replacement a better route?
Thanks
Ed Schulte
09-09-2005 06:00:35
 Re: Front mount hyd pump failure?? in reply to 550Doug, 09-07-2005 16:53:56
If you need a pump I have one in like new cond. 563-927-4919
J. Schwiebert
09-07-2005 17:35:41
What pump do you have a gear pump or a vane pump How much fluid do you have on the suction side? I am guessing you unhooked the pressure line at the pump. Are you sure the pump drive does not have a problem such as a sheared key? Also a collapsed scren leads me to beleive you can not get oil out of the tank fast enough. So have you tried it with the breather off the reservoir? Just some places to start.
