77 / 880 hyd system pressure
Adam Suess
09-24-2005 16:31:26
I need more pressure from my hyd systems on the 880 and 77. Just how high can I push them befor somthing fails? I realisticly need 1800 psi. Is that going too far? High pressure loads are cylenders not motors.
J. Schwiebert
09-25-2005 06:35:18
 Re: 77 / 880 hyd system pressure in reply to Adam Suess, 09-24-2005 16:31:26
It is your money but try to stay under a 1000 PSi on the relief valve setting. We had a customer that purchased a 450 plow one time He had a D-4 Cat and a TD international. One crawler would lift it one would pull it. He purchases a different cylinder and that ended that. How much (in pounds) push does the cylinder need to develop?
Tramway Guy
09-25-2005 06:23:04
I am curious what you are working on. Couldn"t you obtain a larger diameter cylinder?
There is something called a "pressure intensifier", but the expense would be significant.
Adam Suess
09-25-2005 18:38:00
 Re: 77 / 880 hyd system pressure in reply to Tramway Guy, 09-25-2005 06:23:04
currently working on a 10" 72' GSI grain auger that lifts with a large ram. The 77 powers it with ease but won't lift it. I also pull a 27' brillion X wing pulverizer with these tractors but need to run the wing up a ditch to get it to fold over. There are other things they just struggle to lift. The hyd has been the week link in these tractors for me. Just asking too much of them I guess. Thanks.
olg1355
09-26-2005 04:49:32
 Re: 77 / 880 hyd system pressure in reply to Adam Suess, 09-25-2005 18:38:00
One thing to watch for no matter what tractor you are using on that big ram is the fluid level.
Most of those are one way cylinders and can use a lot of oil.
j meyer
09-24-2005 20:10:30
Adam- Get yourself a 1650:) Mines been working out fairly well- hope to post a picture on here soon of it.
Adam Suess
09-24-2005 20:39:39
 Re: 77 / 880 hyd system pressure in reply to j meyer, 09-24-2005 20:10:30
third party image
Glad to hear your 1650 is working out. Here is the 1650 I had. I sometimes wish I would of kept it. The high speed transmission was nice.
90%ret'd
09-24-2005 18:28:22
Best not to exceed 1200 on those, center of pump will fail. Can larger dia. cylinders be adapted?
Would be better than wrecking the tractor pump etc.
90%ret'd
