Jim@Concord farms
AB
10-19-2005 18:16:50
Jim,
Ag parts first, formerly Rick's Agri parts has the seat parts you were looking for on the 1650. Telephone # 1-866-264-9720.
Shock part # 159836A
back pivot bushings (2) #159813A
upper rollers (2) #159829A
lower rollers (4) #159827A
bar springs (3) #159837A
Jim@concordfarms.
10-20-2005 07:53:59
 Re: Jim@Concord farms in reply to AB, 10-19-2005 18:16:50
AB: Thanks a bunch. I appreciate your taking the the time to look those numbers up for me. Jim.
AB
10-22-2005 19:01:45
 Re: Jim@Concord farms in reply to Jim@concordfarms., 10-20-2005 07:53:59
Jim,
I tore into my seat and found that the 3 bar springs part numbers are not right. Any way they sent me 3 flat pieces of metal and I don't see any where they are used on my seat assembly. My seat's biggest problem seemed to be the back pivot bushings were locked up and would not allow the shock to raise and lower the seat. You may only need these bushings and a new shock for yours. My rollers weren't really bad, though I did end up replacing them. All of these parts were new AGCO so you should be able to buy them locally from an AGCO dealer if you have one close.
Andy
AB
10-23-2005 19:23:59
 Re: Jim@Concord farms in reply to AB, 10-22-2005 19:01:45
The spring numbers are right. The flat pieces of metal do act as a spring mechanism inside the turn collar. Sure wish I had a diagram of how this comes apart.
