What Narrow Fronts Would Fit A Oliver 1950?
1950 Puller
10-22-2005 19:39:56
I was just wondering what Oliver narrow fronts would fit a Oliver 1950 with the Detroit?Can you just drop the WF off and bolt on a NF or is there more to it than that?I'm changing classes and need to lose some weight for pulling.Thanks.
TP from Central PA
10-23-2005 05:20:05
 Re: What Narrow Fronts Would Fit A Oliver 1950? in reply to 1950 Puller, 10-22-2005 19:39:56
I put one on my 1850..... ..... ...Was a breeze to do.
Marc Smothers
10-22-2005 20:08:23
Any narrow front for power steering will bolt on. Pull the wide front off, the narrow bolts onto where the bolster bolts. My neighbor's 1950 has had 1 since new.....Good luck, Marc
1950 Puller
10-25-2005 16:24:52
 Re: What Narrow Fronts Would Fit A Oliver 1950? in reply to Marc Smothers , 10-22-2005 20:08:23
Guys,thanks for the info.Now to find a NF.
