1755 PTO or Hydrolic problems
1755
10-24-2005 20:55:04
got out the 1755 saterday to sredd corn stocks terned on the PTO and it did not go it seamed like I was puting it in stop and the lever would not stay on I have less than 100 hrs on hydrolic oil & filter have all the other stuff yet 3Pt hydrolic hook ups jump and swell the hoses like there was presher in there, brakes and stering still all work fine no abnormal noises I took the valve that the PTO lever hooks to the only thing in there was the one side of the snap ring broke off but it did not seem to bind or look bad was free not stuck there was some black stuff in the bottom I put air presher in the PTO where it bolts on I could hear clutch & brake aply and they both held presher put it back and the only diferanse is the lever will stay on now but still like it is in stop insted of on
I talked to the parts man he thought the clutch lining was shot or the splines striped that the pump was alright sens all the other stuff worked yet What do I expect to pay at the dealer to get the PTO rebilt Also found the Hydrolic Temp sensor termanal busted off the dealer could not find a sensor for a 1755 the one for the 1855 is the same am I right
MikeKy
10-26-2005 09:02:47
 Re: 1755 PTO or Hydrolic problems in reply to 1755, 10-24-2005 20:55:04
If the pto is a two speed check the shifter at bottom of housingtoo see if set bolt for shift rod has backed out and shifted too netural.
1755
10-27-2005 15:21:25
 Re: 1755 PTO or Hydrolic problems in reply to MikeKy, 10-26-2005 09:02:47
I looked at that did not see any thing like I backed into something but I never thought about the bolt losining and it shifting I will look into it more thanks
J. Schwiebert
10-25-2005 12:49:00
You could double check the pressure to the PTO. It is the same as brake pressure so if your brakes work I would guess you are close. Did you take the cap off your PTO valve and see if the spool moved? I also remember a few of those valve getting rust in them and sticking. Is there grease in that cavity when you take the valve cap off? Have you unhooked the pin from the linkage and shifted the valve manually so you can feel it enter the correctposition? We also had a few we had to adjust the linkage on. With the tractor shut off and air pressure applied to the PTO pressure port can you turn the output shaft with a long pipe wrench and if so does the engine fan turn? Questions?
Marc Smothers
10-25-2005 02:11:17
First thing I would do is check your rear end oil level. Lots of times the seal in the pto goes and all that valve is doing in essence is dumping oil into the rear end. Your rear end oil should be level with the top hole in your pto housing. As far as the temp. sensor they are the same, but I have instead replaced mine with a tranny temp. gauge that I put in my dash, alot more user friendly than that light. THe worst thing you can have with these closed center systems is too much heat.... GOod luck, Marc
1755
10-25-2005 19:34:05
 Re: 1755 PTO or Hydrolic problems in reply to Marc Smothers, 10-25-2005 02:11:17
J
that is the valve that I took apart and did not see any thing wrong with I had it packed full of good grease no rust or water and it has a good cap I put my pliers on the linkage and it berly moves past where the lever puls it and it did not mater Mark the rear end oil was higher than the plug but it might have been from what was left runing in out of the funel when I filled it did it the same time as the hydrolic oil the oil was milky then but cleen now I put air in the oil holes at the back of PTO and it held presher I will put the temp sensor in for now but would like to have a gauge that would be nise
I went to the salvage yard today and looked at a 17 or 1855 and a 2-150 ones that did not have the plat form and floor bords dont know witch but the Oliver did not have external 3pt cylenders The lines were all there and there was a box that the line from the pump goes to then to the PTO valve at the back could it be sometheng in there it would be under your left foot under the floor the 2-150 did not have that box but the lines were not quite where they were supost to be it looked like it had a T but not quite shere if it was the same line melted cab glass was in the way I was going to put a gauge on the hydrolic hookups but did not get time yet wont get back at it tell friday thanks
1755
10-28-2005 19:10:22
 Re: 1755 PTO or Hydrolic problems in reply to 1755, 10-25-2005 19:34:05
I looked into the shifter going to nutral holding the lever in on and moving the shifter It did not make any diferance
put air in the line frome the pump to the PTO valve and put a bar on the pto it would hold alitel but the whait of a long crobar was it in stop or on it would bubel in the hydrolic tank to I am thinking it is going to have to be checked out to see if the clutch is shot thanks
