Cab for 2255?
Adam Suess
11-27-2005 17:38:33
third party image
I'm thinking about putting a cab on my 2255. Currently has rops canopy. As my main tractor I have to operate it in bad conditions more than I like any more. Any one install a 2-105 or 2-135 cab on a oliver 55 series? If so how did it turn out. What color did you paint it and does it look out of place on the tractor? I need to keep my tires set for 30" rows so a factory cab is unlikly to work. Thanks
Marc Smothers
11-29-2005 06:30:06
 Re: Cab for 2255? in reply to Adam Suess, 11-27-2005 17:38:33
My 2255 came from the Factory with a White 3 sided cab. It is my understanding it it a 2-150 cab as these tractors had the same rear end. I certainly could move my wheels in far enough for 30" rows. I too have seen others that had a White cab added, most are green with Clover White tops, mine is Clover White. I have been told an easy way to figure if it came from the factory with that cab is where the fuel tank is located, I don't know if this true is or not. I do know this is one unique tractor I have and will try and get a picture on here if I can get to it in the building..... Marc
WFE
11-27-2005 19:25:44
Adam,
My 2255 with factory cab has the fender fuel tanks integral with the cab. Tractor has 18.4R38 radials on it set on 60" center-to-center for 30" rows. There is not a great deal of clearance between the tire and fuel tank for mud, but it does fit. I rather have the idea that I'd like to make mine into an open station tractor with fender tanks. I am hoping to get a chance to look around for the open station parts and fender tanks this winter. If I'm successful, I probably won't keep the cab, even though it is in nice shape and has heat and A/C. I'll keep you in mind if I need a place to go with it.
Adam Suess
11-27-2005 20:42:24
 Re: Cab for 2255? in reply to WFE, 11-27-2005 19:25:44
If you want fender tanks send me a e-mail. There are 3 or 4 sets around here that need a home befor they get scraped. If you see any good 4-180 whites for sale out your way let me know. If I can find a good reasonably priced 4-180 close, I would leave my 2255 the way it is. I really don't have enuff tracton or power in the 2255. New radial tires would solve that, but then the cost is near that of a 4-180 which would have more of both and a cab. Thanks
WFE
11-29-2005 18:10:06
 Re: Cab for 2255? in reply to Adam Suess, 11-27-2005 20:42:24
How about a 4-210? You'd have the later version (red stripe with WFE badging), with inboard planetaries, and Over/Under, not to mention stronger articulation joint, two steering cylinders, and a newer version of the 3208. I have access to one that is a later model. I'll send you an email with the details to see if you'd be interested.
Wrenchbender
11-27-2005 18:31:06
Hey Adam, I would look for one from a 2-105 or 2-150. The 2-135, 155 has the gear shift mounted on the side console and the cab mounts may be different since the transmission/rear-end is not the same. Just a couple things to think about. WB.
Shep VA
11-27-2005 17:52:47
I have seen White model cabs on the 2255s before and I dont think it is too bad of a conversion. Most I have seen painted the cab white or a comination of white and green.
I know Farmersville Equipment has a few cabs and I know Wengers has one also. If you decide you want a cab let me know and I will hook you up with them.
I got dibs on your canopy when you change to the cab!!!!! :-)
Don-Wi
11-27-2005 18:07:21
 Re: Cab for 2255? in reply to Shep VA, 11-27-2005 17:52:47
NO FAIR!!!!! !!!!! !! Can we atleast flip a coin? Some time I plan to start gathering parts and components to make our 1755 into a cummins hybrid w/ a canopy and fuel tank fenders.
What do you call a 1755, which has an 1850 tub & bell housing, an 1855 rear end, a cummins 5.9 and the only 1755 parts left are the front axel, the sheetmetal(doubtfull) and the dash??
I'm thinking 1785-C
Adam Suess
11-27-2005 20:52:57
 Re: Cab for 2255? in reply to Don-Wi, 11-27-2005 18:07:21
Sorry the canopy is not for sale. I would put it in storage in case I would want to convert back. Last spring when I had the tractor painted. The metal shop made part of a new top for me. The original had rusted out in one spot and then I bent it with the 3pt forklift. Not all that expensive to make but the hard part is the roll bar as the posts taper.
Larry NE IL
11-30-2005 19:06:17
 Re: Cab for 2255? in reply to Adam Suess, 11-27-2005 20:52:57
Hi Adam,
I've got a 4-180 thats going to a sale in March. If you are interested, e-mail me. I rebuilt the center pivot and put a complete exhaust system on it, and new interior. The air conditioner dosen't work. Got a set of duals for it too.
Or You can call me at (630)774-2087
Larry NE IL
11-30-2005 19:05:25
Hi Adam,
Larry NE IL
11-30-2005 19:01:34
Hi Adam,
