Oliver 1650
Adam Schuh
11-28-2005 21:42:13
I have an Oliver 1650 Gas. I am wondering how much gas usage is normal. This tractor really seems to suck a tank dry. I was plowing this fall with an Oliver 566 4-16 and used about 8 to 10 gallons per hour. Is this normal or is something causing me reduced fuel economy. Should probably go to a diesel, but this tractor is my favorite, pulls strong and runs good all the time.
B A Star
11-29-2005 18:41:48
 Re: Oliver 1650 in reply to Adam Schuh, 11-28-2005 21:42:13
Answer to Jonnnie T's question, The Oliver 1850 Gas tractor test is number 875. On the maximun PTO test, 92.43 HP @ 2400 RPM, it consumed 7.701 GPH. This would be a constant pull for one hour. On the Drawbar Test, @ 75% of load for one constant hour, it consumed 6.981 GPH. The 75% drawbar would be more like the use you would have in the field as I am sure you are not pulling 100% all of the time and are turning at the ends also.
Johnnie T
11-29-2005 19:18:15
 Re: Oliver 1650 in reply to B A Star, 11-29-2005 18:41:48
Thanks Mr. Star I just overhauled this one electronic ign. new carb clutch, & hyd pump and its running like a top pulling that 24 ft harrow and looking for moreshore love this big ollie Thanks for the answer
Bob M
11-29-2005 06:14:09
Adam - Your fuel consumption sounds too high to me too. Our 1650 gas burns 6 - 7 gallons/hr pulling a 5x14 plow in 3rd direct.
Make sure the ignition timing is set to spec, and that both the centrifugal and vacuum spark advance mechanisms are working. Then try leaning the carb high speed mixture screw to where the engine begins to lose power, then opening it back up 1/8 to 1/4 turn.
Good luck - the 1650 is one of my favorite tractors too!
Johnnie T
11-29-2005 17:22:45
 Re: Oliver 1650 in reply to Bob M, 11-29-2005 06:14:09
Mr. Star what does Nebraski test say on gas consumption 1850 gas per hour Iam figuring 6 per hour pulling a 24 ft disc in black soil in S texas heat in 4 under
Bob M
11-30-2005 05:35:23
 Re: Oliver 1650 in reply to Johnnie T , 11-29-2005 17:22:45
Our 1850 gas will consume 7-1/2 - 8 gallons/hour pulling a 6x16 plow in 3rd under/2nd direct. This is in gravelly soil in cold upstate NY.
Adam Schuh
11-29-2005 08:00:04
Wow Bob, 5-14 in 3rd direct. I can't pull my 4-16 in more than 2nd direct or the tractor lugs down way too much. What kind of soil you have where you are. Mine is dark black topsoil, not heavy clay or anything like that. I don't know, maybe I'm plowing too deep, how deep do you run.
Bob M
11-30-2005 05:40:27
 Re: Oliver 1650 in reply to Adam Schuh, 11-29-2005 08:00:04
Adam - We're plowing mostly glacial moraine - sandy, gravelly stuff that plows easy. However on the river bottom (clay/muck) we gotta drop to 3 under or 2 direct.
Incidentally operating in the lower gears without an extra 500# hung on the front end it's difficult to keep the front wheels on the ground.
B A Star
11-28-2005 22:27:59
Nebraska Tractor test for a Oliver 1650 Gas burnt 5.814 GPH under max load.
