1650 Tire Spacing
Adam - WI
12-23-2005 17:40:51
In the owners manual there are charts for rear wheel spacings. Are they talking outside to outside here or center to center. How hard are they to move.
Don-Wi
12-24-2005 08:21:17
 Re: 1650 Tire Spacing in reply to Adam - WI, 12-23-2005 17:40:51
How hard they are to move depends alot on how long they have been in that spot and how much patience you have. The ones on my 1600 weren't tooooo bad once I had the tires removed and only had to contend with the hubs. They were tight since it was new also. I soaked them down with PB Blaster and let themn sit for a few days. I also The nuts came out fairly easy, but I had to beat the u-bolts out with a BFH. Leave the nuts on while doing this and you should be able to reuse the u-bolts. I only messed up 1 of mine and now it's narrow enough to cultivate our corn on 32" spacing.
Donovan from Wisconsin
B A Star
12-23-2005 18:42:48
Wheel spacing provided in the OM is center to center dimension.
Adam- WI
12-23-2005 20:14:24
 Re: 1650 Tire Spacing in reply to B A Star, 12-23-2005 18:42:48
Thanks, you would think that would say that in the manual.
