1850 steering problem
1850 Oliver
03-05-2006 17:27:52
Oil was leaking around the shaft on the steering hydra motor,I went to fix it and found out the splines are worn off the shaft and the steering tube and also has been welded before,does any one have any parts to fix it or have any ideas; any help would be appreciated
Fern(Mi)
03-05-2006 20:02:52
 Re: 1850 steering problem in reply to 1850 Oliver, 03-05-2006 17:27:52
If it is a Saginaw, somebody is rebuilding them. However if the splines are as bad as you say, you’ll likely need another boneyard replacement. If it steering motor is a factory or after market replacement, check "Burden Surplus Sales" for replacement motor and companion steering shaft part. LUCK.
I’d tell more, only dead tired.
Fernan
