77 Oliver pulling power
77 Oliver
03-25-2006 19:57:35
I have a 77 Oliver that I am wanting to get more power out of for pulling.I would like to get more cubes out of it.Would it be best to find bigger Waukesha engine to use;If so what do I need to look for and what do I need to do to it.Any help will be appreciated, Thanks
A.P.
03-26-2006 03:27:10
 Re: 77 Oliver pulling power in reply to 77 Oliver, 03-25-2006 19:57:35
It all depends on wwhat the rules for the groups you are planning on pulling with allow. Better off starting there instead of building something that they will not let you pull. A lot of engines will "fit" (fit being a very vague term open to tons of latitude), but it depends on how much work you are willing to do. How many horsepower do you need to compete with the tractors alrready running? What weight classes do you plan on pulling? Is there a spead limit or gear limit? What size tires are you allowed to run? Are they allowed to be modified?
