White 2-180 Hydraul Shift
4440 puller
04-20-2006 07:00:36
I have a White 2-180, over under transmision. Overunder oil temp would get hot, no preasure, except when cold, it would react to Engine RPM"s.
I have the tractor all tore apart, engine and trans out of the tub. the only thing i have found so far is the bypass plunger seems to have not been seating correctly. We have tried to get the seat out for the bypass plunger but havnt been sucessful. The pump looks to be good, have tried changing fluid and filter before tearing down. Any ideas would be helpful as we are hoping to have this girl out running in the field this spring.
J Schwiebert
04-20-2006 09:41:27
 Re: White 2-180 Hydraul Shift in reply to 4440 puller, 04-20-2006 07:00:36
Did you check any of the pressures before you tore it down> How much of it is torn apart now? Have you pressurized either the direct or overdrive clutch? Have you checked the direct drive clutch seals? Enought for now, end of lunch time Your turn. J.
