4-180 WHITE parts
AGCOGUY
05-15-2006 19:42:26
Would anyone know of a supplier other than AGCO for the articulation bearing on a 4-180 WHITE. AGCO wants over 500 for it..didnt really want to have to shell out that much.Thanks for any info
davpal
05-15-2006 21:13:41
 Re: 4-180 WHITE parts in reply to AGCOGUY, 05-15-2006 19:42:26
You can get a good used one through just about any tractor salvage. A lot of those center sections are lying around in the yards. I would bet a lot of bearing companies like detroit ball bearing or Motion industries can get a new one much cheaper than agco. I really like the price for the "field package" not! with the pin and bearing and seals. $1000 bucks. I am pretty sure they charge at least one thousand dollars for every item at the agco store. Pretty scary working on those center sections. I had every block around the place used to shore that tractor up when I did one. I even put my fork lift truck under the front section to keep it from tipping forward when I was working on mine. Those front ends hang out there a long way and that 3208 is pretty heavy hanging out there. Good luck, be careful!
